BV9 full HD
Oasis
Posts 49
Oasis Posted: Fri, Dec 4 2015 12:42 PM
Will it still be possible to convert a MKI standard definition (720p) BV 9 to full HD (1080p) BV9?
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Depends on whether you want to place an original B&O panel and if they're available.
The mk1 is a hd-ready (not SD) version.
The BS3 can easily drive the newer panel. It might need a software update, but I don't know if that's necessary.
The newer panel will be recognized by the BS3 via it's DVI module
The mk3 has full HD and the calibration camera underneath the bessel. That's something you still miss.
Oasis
Posts 49
Oasis replied on Sun, Dec 6 2015 7:46 AM
Thanks. I will check with the dealer
Page 1 of 1 (3 items) | RSS
