Gentlemen,
I am lacking the original power supply of a BeoCom 2 combined base station. Does anyone have information regarding the pinouts of the BeoCom 2 base station cable (Mk 1)?
There are two connectors on the cable. One RJ45 which has four wires connected, two on each side of the RJ45. I assume these are the ones that connect to the power supply. But why are there four wires and what is the function of each wire? The other connector is a standard RJ11 with only two wires so I assume it has nothing to do with powering up the base station, as is the case with BeoCom 4 and 6000.
Regards!
