Which Cat for RJ45-beolink
This post has 1 Reply | 0 Followers
Mogelmose
Posts 88
Mogelmose Posted: Tue, Dec 8 2015 5:39 PM
Hi guys? Which category cable should i use for wiring my beolab?
It is from wall to speaker - 30-40 centimeters. They are going to be run with the powercable in a sleeve but i don't know if noise is an issue when the distance is this short?
Mogelmose
Posts 88
If i get a Cat5E FTP? Would that be enough?
I am going to solder a Powerlink plug on the other end as the speakers are Beolab 8000.
I may specify that the systems is not "true" NL as the cables in the wall and from the master to the walls actually are powerlink.
The only reason for RJ45 is that i need a pretty wallsocket for the installation. So i convert the Beolink MK3 cable to RJ45 and then back again when in reach the speaker.
Page 1 of 1 (2 items) | RSS
