I want to connect my ipod via bluetooth, and my pc, whilst playing music through my pair of speakers. what amplifier do i need and with what cables? thanks!!
Or just a jack plug for my iPod, I just want to play party volume music, presumably going : iPod - amp - speaker??
ok great! what sort of cables and amp would i nee, do you have an example/links to them? :) thanks
I used to use them in my younger years for parties with a Harmon Kardon amp and they were excellent with Dance/Electro music - it was an HK6150 I think, probably you could get one second hand on eBay if you chose not to go the B&O receiver route, but there are plenty of others out there. You will need speaker cable and if using a B&O amp DIN speaker plugs on the end - most likely you would need Din to Jack as well with B&O - but well worth the effort.
