Can I use a Beocenter 6-26 in same sort of link mode only?
I want to try it as Computer Monitor and since I have a Beovision 4-42 in the same room, I would prefer to use Link-PC to start the BeoCenter 6-26 in PC Mode.
Thanks for your help.
Ralf
Hi Ralf,
I'm pretty sure the BC6-26 supports v.opt 4 so you should be able to set it to this option and then use L-PC (or use a dedicated beo4 set in permanent link mode) to do this.
Kind Regards,
Martin.
