Hi - I am new to this forum and I am looking for some help!
I ran across this Beolab 5000 and Beomaster 5000 and had to buy it...
It was first sold by Niels Jørgensen, Radio- og Fjernsyns-Service in Nakskov 25 may 1967 (four months before I was born)
It plays but need cleaning and service - where to start and how much should I do - I have been looking into Søren Mexicos great post about his BL 5000 - many are refering to Martin/dillen and Fred for new caps and lamps... Any help to get this started will be highly appreciated :-)
Thanks //Bo
And here are some images :-)
Seems like only part of my images made it...
Probably the best solution is to send it to Frede (Classic audio) for precise restoration.
See also: http://archivedforum2.beoworld.org/forums/t/17283.aspx
priklep: Probably the best solution is to send it to Frede (Classic audio) for precise restoration. See also: http://archivedforum2.beoworld.org/forums/t/17283.aspx
Agree with Priklep, but if you want to do it yourself, you have seen my thread, if you dont know anything about electronics dont do it, if you have the instruments needed and know how to use them I dont see a problem, but before I write a long answer about what I will do in the next one, and what I didnt do in mine, you have to decide what you want.
