Hi all
I am new to this forum. The cable for one of my speakers came loose and the speaker stopped working. After investigation, I found that a piece of the cable broke off. When taking out the cable, the connector shows two small metal protrusions, I am guessing one for the positive and one for the negative.
Does anyone know which one is which?
Welcome to Beoworld !
The plug is a standard 2-pin DIN speaker plug.Round pin positive.Flat "spade" negative.
Thanks for the reply I get right on to fixing that
