Merry Christmas all,
I've recently changed my sound system to (almost) all vintage B&O. BG8000, BM6000 and Beovox 3000 flat panel. The only remnant of my old system is the Creek preamp. I now have the 8000 hooked up to that with the output going to Tape 2 on the BM6000. This set up sounds excellent. I have also tried the DIN to RCA directly into the 6000 Phono. Sounds good too. Of course, if I want to use the Terminal remote with the 8000 I would have to use DIN to DIN into phono and ditch the Creek. Tape 2 is quite awkward, as it is not on the remote either. The Creek is perfectly set up for the mmc20cl with the dip switches aligned for that cart. What would you do? I like the sound of both.
I also need an antenna for the radio. It already picks up a station quite clearly with no antenna. What antenna would I need? The only one I had lying around had a male plug but the BG6000 seems to require a female connector.
Thx
