I just posted a to en existing thread in the workbench, and when posting I got the message " you are posting to forum that requires moderation" whats going on here, its my own thread and no obscenities was posted
I just had the same experience. Tried to start a new thread with a post that mentioned Beosystem 3, Beosystem 4, Beovision 7, Avant, Beolab 9, 20 and 5s. I received the same message you did. Since I used the same words in this post, I wonder if it will allow it to be posted. Very frustrating.
It will be posted eventually, but something is wrong somewhere, non of us use bad language or post pics of naked persons
The post did appear. However, I noticed I had left a couple of words out. As I can not edit a post on an Apple computer, as has been mentioned here before, I got out my ancient Windows laptop. Went to the forum and the post was nowhere to be found, even though I could now see on my Apple. So I went back to the Apple, copied the previous post and posted it as a reply. Exact same post as the first time except added a reference to Beosystem 3 and a reference to the Avant, as well as mentioning that it was just to clarify previous post. Again went to moderation. I am sure it will appear, perhaps even before I finish this post.
I was wrong. Checked to see if second post had appeared. Not only has it not appeared, the first post and entire thread have disappeared.
There's currently nothing waiting to be moderated and nothing was deleted since december 24th.Which thread are we talking about ?
I've had posts automatically held for moderation in the past...... probably 50% of them eventually appeared but the other 50% simply disappeared. This suggests that the auto mod does not always hold posts for moderation but may delete some of them completely without a moderators knowledge.
Of those posts that do post straight away the auto censor does odd things as demonstrated in the gourmet thread. Chicken breasts (plural) are OK, but turkey *** (singular) is not (and should appear as asterisks here if I am correct.)
Graham
Dillen: There's currently nothing waiting to be moderated and nothing was deleted since december 24th.Which thread are we talking about ? Martin
The posts I made in the Beosystem 3 compared to Beosystem 4 thread have appeared now.
