I have a Beocenter 2 and a Beo 4 remote which works wonderfully.
Each time i put on my Samsung TV that is connected to the Beocenter 2 (DVD) the remove will not control the Beocenter 2 any longer.
If i off the tv the remote will start to work again. What is the problem... can't control the volume or change track of the Beocenter 2 while tv is on.
The only way that the remove works is to stand infront or stay up very very close to the beocenter w2.
Help is annoying..........
This problem is cased by an interference between the TV panel and the IR sensor. You can work around this problem by trying to find a new position for BeoCenter 2 where the TV doesn't interfere. I had a similar problem, it worked when I put the IR-sensor beside the TV with a ditance of at least 1,5 m
hfat
