bs5 (e) with beolab speaker an foreign preamp and tv
This post has 1 Reply | 2 Followers
manitou
germany
Posts 61
manitou Posted: Fri, Jun 29 2012 12:49 PM
hy,
i am going to buy a bs5 (e), to use it with a foreign preamp to switch sources and manipulate sound. the tv is a foreign product to.
now my question: how do i connect the bs5 (e) best with my existing system?
can i use the ripping module with  with bs5e as well?
should i get bs5 or bs5e?
grüße horst
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Fri, Jun 29 2012 2:39 PM
Simplest: BS5 connect it with spdif and/or analog to the preamp. I would go for the spdif. Then the signals are send digitally to the preamp
The BS5e doesn't have a ripping module; the BS5 does
Page 1 of 1 (2 items) | RSS
