I have Beocenter 9000 with following problem. When I insert CD spindle motor doesn't rotate at all and there is no laser-beam at all. I have tested that spindle motor and laser are working in other unit, so they are ok. So if anyone has good ideas they are welcome
Here is a couple of pictures from the board. I am also interested if someone has for sale board like this or is interested to fix this board. Unit is CDM 4/30.
did you fix it? i have a cd unit with the opposite issue. mine spins and reads but no sound. I suspect your problem could be fixed by my cd / servo board?
