I had a question about this system. Would one be able to connect a set of Beolab 4000 speakers or say a set of Beolab 6000/6002 to this system.... I know it has probably been asked before. I just could not find any information on it. Plus how does it get say something like internet radio on it? Does it hook up to the Internet?
Yes you can, there is two RJ plugs on the essence to connect directly speakers, so if you buy the rifht cables (RJ -> Powerlink) you can definitely put your 4000 on it.
For the internet radio, everything is done through BeoMusic APp and then the Essence is grabbing the stream from internet.
I have a second hand MKI if you want (without the wheel) as I upgraded the white box to a MKII to benefit from MultiRoom.
Christophe.
Beolab 1, Beovision 7-32, Beosound Moment, Beolab 18, Beolab 19, Beoplay A6 Grey, Beoplay A6 Black, Beolit 15, Beoplay H7, Beosound Essence mkII waiting for speakers :)
You need the wheel if you love the look and want to be able to resume last played source without using your telephone or tablet, otherwise everything is done through the app.
I am located in France.
On the offer : make me your offer keeping in mind market price (it s still under warranty for 11 months as i bought it.on the 24th of december 2014.
Christophe
