Beo5 configuration
OlliNeu
Posts 21
OlliNeu Posted: Sat, Jun 30 2012 11:12 AM
I have a question and hopefully somebody can help me.
I try to make chain of signals with pressing one button. The row should be
1. switch on DVD on BV7-40
2. switch on light cofiguration over JB-Media
3. switch on CD-MEM on BS3200 without switching off the DVD
The BS3200 is connected via masterlink to the BV7-40. I can control everything, but when I try to switch to CD-MEM the TV is switched off. If I do the control manually I have a button AV... on the Beo5 and so I can switch on the BS3200 without switching-off the BV but I cannot get any control from the button AV...
Has somebody any hint?
Oliver
hfat
Vienna, Austria
Posts 663
hfat replied on Sat, Jun 30 2012 1:33 PM
To get the functionality of the av button you have to use the address part of the ir command.
In normal situations switching on the cd would be like "...radio cd". To get the av-cd command code as "... Tv cd".
I hope the explanation is clear enough, I cuurently cannot access the tool. If not I'll give a more detailed info when I'm home again.
Hfat
OlliNeu
Posts 21
OlliNeu replied on Wed, Jul 4 2012 8:45 PM
Perfect! Now it works. I forgot the "TV-mode" before switching... Thanks a lot.
Page 1 of 1 (3 items) | RSS
