Hi all,
i dont know why, but i cant reach the webinterface anymore (i gave an ip and started programming already!):
mlgw seems to boot normally (about 40 seconds, then green front panel indicator)
i tried various workarounds:
reset network setting with setup button (function 3 or 4)
restarting mlgw on factory-installed software
set al a local direct linked mac back to ip 192.168.1.11 to reach 192.168.1.10, its not detected by a network scanner...
Any ideas??
Thanks,
markus
are you typing "mlgw.local" into your browser? I often make the mistake of just typing "mlgw" which can give a different result.
now i got it, after about 20 times rebooting and starting from the very beginning...
Dont really know what went wrong!
Thanks for your help,
