I have a BeoLab 3500 speaker with a BeoWireless system to link to my Beosound 3200 system. However, due to the distance between rooms, I am finding it very hard to get a good connection and the Beolab speaker constantly cuts out. Is there any way around this? Can I buy a cable to fix this problem or is the only option to put the two wireless boxes closer together? Your help would be greatly appreciated!!
You could simply hook them up through a master link cable. You can get them terminated with the ML connector from this boards suppliers.
Firstly, check that the wireless 1s have the same and latest version of software on them (they can be flashed) - performance is spotty otherwise even If they are next to each other.
Having said that, I stopped using them for exactly the same reason - they worked intermittently.
