BeoMaster 5 Windows Error
This post has 3 Replies | 0 Followers
Hildering
Posts 3
Hildering Posted: Fri, Jan 29 2016 8:34 AM
Hi there
i've got a BeoMaster 5 and it's stuck on Booting
there is an windows error message with file missing or corrupt:
\windows\system32\config\system
1. how can i get access with keyboard and mouse, just connect to the 2 USB Ports at the BeoMaster?
2. how can i repair that error? simply use a windows cd and run the recovery?
TWG
Posts 1,672
TWG replied on Fri, Jan 29 2016 9:05 AM
1.) yes
2.) NO! It is an embedded Version of Windows XP, not the standard customer version. But there's a recovery partition on the harddrive which should be accessible.
Hildering
Posts 3
Hildering replied on Fri, Jan 29 2016 1:08 PM
well i figured out how to do a recover installation but there are 3 driver errors at the end.. i skipt them but then the BeoMaster just showing the Bang & Olufsen Screen..
May i need this Beo Service Tool Stick?
Hildering
Posts 3
edit: doublepost
Page 1 of 1 (4 items) | RSS
