Hi all,
I recently saved a Beogram 1902 from a dusty storage. The cover is slightly damaged, and although the unit turns, the arm will not swing out (though it does lower). I'd like to send it out for repair. Does anyone know a reputable repairer in London or the UK that I could get in touch with?
Thanks in advance,
MongrelNomad
Googling around for something B&O related, I came across this site. It's a hifi repair shop in London and lists B&O as products they handle. I make no claims as to how reputable they are, but , it's worth an estimate if you're intent on getting your 1902 fixed.
http://www.londonsound.org
Hello - I can recommend Quality Dream Audio (you can find them through Google search engine). I use this company all the time to service and repair my equipment. I had a range of turntables repaired and serviced by this company over a number of years and find them highly efficient. Their email is:
info@quality-dream-audio.co.uk
You are quite at liberty to say that ProfD sent you to them. I hope that this helps.
Professor David A Flynn JP LM
Thanks for this. I have dropped the chap an email too, fingers crossed he can fix my Beograms!
Thanks for this. Have dropped him an email... fingers crossed he can fix my Beograms!
