Hi everyone,
I have bought the bluetooth receiver for my A9 as the connectivity with Wi-Fi is horrible. There seems to be a problem with the line-in though. I have tried playing via the receiver and also directly from iPhone with line-in, and it does not work. Any ideas?
It works fine with the Wi-Fi (until it randomly drops from time to time, or can't connect)
Thanks in advance!
Did you turn up the volume on the connected device/s?
Usually this should be set to nearly max and the volume control should be made by the A9.
Notice - when you start be sure, that the volumen of the A9 isn't too high.
The line-in connection should autodetect/autosense, that there is something playing and switch the A9 to line.
If you have a Beo4 (?), have you tried pushing 'A.Aux' to activate the line-in of the A9?
I tried maxing the volume on the A9 and the iPhone, also set it to Maximum in the BeoPlay app on my iPhone. Didn't work.
I don't have Beo4 unfortunately.
