how do I enter through my BO4 controller a 4 digit code as it says on instruction press LIST then (( twice and then EXIT, but where is EXIT on my controller ? If i press the red button at lower left nothing is called up !
Welcome to the forum!
Are you trying to enter the password/PIN for e.g. a Beovision?
To my knowledge you only need to enter the pin with the numbers on Beo4 and press "GO" button (the center button).
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
