Beocenter 2300 only noise on right channel
Zelander
Posts 2
Zelander Posted: Mon, Mar 7 2016 10:09 PM
I have a Beocenter 2300 connected to BeoLab 8000's which has developed a problem with no sound coming from the Right channel. When I switch the L/R speaker switch to L on both speakers then sound is good out of both. When I switch either of the speakers to R then I hear a low pitched noise signal only, from that speaker. Interchanging the powerlink cables makes no difference. Selcting CD player, Radio or Aux source makes no difference. Can anyone point me to where the problem might be?
ipaul
Posts 422
ipaul replied on Tue, Mar 8 2016 12:23 AM
1-check if the balance on the 2300 is not set to L
2-check with headphones.
Zelander
Posts 2
Zelander replied on Tue, Mar 8 2016 10:14 AM
Problem solved! The speaker switch on my R BeoLab was set to LINE....EmbarrassedEmbarrassed
Thanks for your reply anyway.
Page 1 of 1 (3 items) | RSS
