Dirigent, FM / FM-A / FM-B ??
ipaul
Posts 422
ipaul Posted: Wed, Mar 16 2016 8:56 PM
Has anyone an idea, or experienced what happens on the positions of the source switch of the Dirigent, in the case of an FM stereo version ?
So far i found the diagram of the non-fm-stereo and even there the rotary wiring is unclear.
It seems the fm-stereo only plays on 1 channel when switched to FM-B, no idea if this is ok...
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Wed, Mar 16 2016 9:27 PM
It's OK.
The first FM stereo test-broadcasts was done using two FM (mono) frequencies, one for left and another for right, thus requiring two receivers.
You could use the FM-B setting, in which the Dirigent would receive one of the channels and send it to one speaker output.
You could then connect a second receiver (f.e. a Beolit) to the Dirigents Radio socket and tune it to the second frequency.
The Dirigent would then send its signal to the other speaker output, thereby reproducing the stereo signal.
I deliberately use past tense because the 2x Mono = Stereo broadcasts was soon dropped in favour of the MPX encoding.
Today, you need the optional MPX stereo decoder to produce stereo, in which case the FM-A setting should be used exclusively.
ipaul
Posts 422
ipaul replied on Thu, Mar 17 2016 12:28 AM
Ah, ok, never seen this on any receiver/radio, but interesting.
thanks !
Page 1 of 1 (3 items) | RSS
