Beocenter 9000
oleviking
Posts 3
oleviking Posted: Thu, Mar 17 2016 7:22 PM
Just purchased a Beocenter 9000 with Read line speakers. The right speaker output is not working could it be a fuse or would it be more serious - right now we are running speakers on two left outlet..
ipaul
Posts 422
ipaul replied on Thu, Mar 17 2016 8:44 PM
Did you try speaker 2 as well ?
many times speaker 1 interrupts because of dirty relay contacts, in that case sp2 still works.
Guy
Warwickshire
Posts 2,590
Guy replied on Sat, Mar 19 2016 10:09 AM
oleviking:
If both R&L speaker 2 sockets work then it could well be the mute relay - mentioned elsewhere on the site.  A quite simple thing to replace but best to get someone qualified to fix if you are not happy using a soldering iron yourself.
oleviking
Posts 3
oleviking replied on Tue, Mar 22 2016 3:34 AM
Thanks Guy
It was the mute relay, thanks for your help.
Best regards
Ole
oleviking
Posts 3
oleviking replied on Thu, Mar 24 2016 3:56 AM
I am looking for the top glass plate for my Beocenter 900 - does anyone have one for sale or where would I be able to find one.
Best regards
Ole
js
Posts 382
js replied on Thu, Mar 24 2016 8:49 AM
oleviking:
You are lucky to have been allowed to post this. Previous posts of mine were moderated when they included something similar to the second part of your question, because moderators incorrectly assumed I actually intended to try and suggest the first part of your question, which is not allowed in this section of the forum.
Anyway, good luck with your 9000, this is a wonderful piece of kit.
Page 1 of 1 (6 items) | RSS
