laser pickup for beosound 9000
This post has 5 Replies | 0 Followers
wokbelly
Midwest USA
Posts 39
wokbelly Posted: Fri, Jul 6 2012 10:43 PM
I have a Beosound 9000 type 2659  i have intermittent pauses in songs and was told a while back the laser pickup could be bad could someone point me he right direction to who sells or rebuilds these? Thanks
valve1
The south of France and occasionally Dublin Ireland
Posts 1,502
valve1 replied on Sat, Jul 7 2012 8:07 AM
Tell us where you are and someone might know a local dealer/repair center.
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
I don't recognise the type number but never the less, you would be well advised to try and purchase the relevent kit for your particular model from a B&O dealer, as you will end up with the equivalent  to the Mk3 model which have proved to be more reliable in the laser/servo department.
Regards Graham
wokbelly
Midwest USA
Posts 39
wokbelly replied on Sat, Jul 7 2012 10:27 PM
Sorry its type 2561
Daniel
Svinarp, Sweden
Posts 1,632
Daniel replied on Sat, Jul 7 2012 10:51 PM
Happened to my BS9000 at the age about 11. Had the CD mech changed and it works again. Don't remember the cost, but it was not expensive. The fix didnt upgrade the machine to Mk3, as Netradio and Netmusic is still not possible.
joeyboygolf
Posts 4,188
You will need to ask for the S/W to be upgraded to version 2.21 at the same time, if you want N-Radio and N- Music.
Should cost very little extra.
Regards Graham
Page 1 of 1 (6 items) | RSS
DigiCert Secured Site Seal
