I can't get past the About screen on the B&O Moment. No matter what I do it is stuck there. Can anyone help? The dealer has failed to reply to me.
A6 and Moment having an issue, I would suspect my home network.
Is this a new install or an older one that has started playing up? More details would help with diagnosis.
First and obvious is to power off and on again. Also check that the cover is seated correctly over the cable sockets on the rear. When the cover is removed the display goes to the set up menu.
Opman
