Help! Speaker plugs for Beomaster 1000
This post has 8 Replies | 2 Followers
Graham74
Posts 3
Graham74 Posted: Sat, Apr 2 2016 3:00 AM
i have just received a Beomaster 1000 from a friend but there are no speaker plugs to connect to the amplifier.
As I am not great technically I'm not sure if I should use the 2-pin DIN plugs I have found on eBay or if some other type of plug is required. Also is it 2 plugs per speaker or one?
Any help is greatly appreciated!
regards,
Graham.
chartz
Burgundy, France
Posts 4,171
chartz replied on Sat, Apr 2 2016 11:17 AM
Hi Graham!
Yes these are the ones! Smile
I do not know where you live (in the UK I reckon Confused ) but here in France they are still widely available at DIY outlets and component retailers', and they are very cheap.
One DIN per speaker it is. The small peg is the + and the flat one is the -.
Welcome to Beoworld!
Jacques
Ben_S
UK
Posts 631
Ben_S replied on Sat, Apr 2 2016 1:46 PM
Jacques is correct!
you can pick them up from most DIY shops in the UK as well!
Ben
Xseries
Posts 445
Xseries replied on Sat, Apr 2 2016 7:05 PM
These will do the job for you:
http://www.ebay.co.uk/itm/2-X-2-PIN-SPEAKER-DIN-PLUGS-MALE-HI-FI-CONNECTORS-EASY-FIT-SCREW-TERMINALS-/190882903916
http://www.amazon.co.uk/Pack-Speaker-Loudspeaker-electrosmart-Connections/dp/B00512QE4I
If you do not want to solder then the screw terminals would work....
Enjoy the music !
Brian
Xseries
Posts 445
Xseries replied on Sat, Apr 2 2016 7:06 PM
Enjoy the music !
Brian
Graham74
Posts 3
Thanks Brian!
Graham74
Posts 3
Thanks Jacques!
chartz
Burgundy, France
Posts 4,171
chartz replied on Sat, Apr 2 2016 7:41 PM
You are most welcome Graham.
Jacques
chartz
Burgundy, France
Posts 4,171
Double post again. Angry
Jacques
Page 1 of 1 (9 items) | RSS
