Is thisMMC cartridge beyond repair?
This post has 8 Replies | 2 Followers
MJBeo
Netherlands
Posts 270
MJBeo Posted: Sun, Apr 10 2016 7:53 AM
Hi, I have a MMC without tip or stylus (see the attached photo). Can this be repaired by the right experts? Or is it a lost cause? I actually do not know if this part even works...
I don't know which MMC it used to be, because I got it like this. Can it be turned into any of the range?
Thanks!
Beosound 5 Encore + Beosystem 5500 + S45.2; BV7-40 MKV + BL7.1 + BL14.4+ AppleTV4; various link rooms with MCL2 A or MCL2 A/V + RL60.2 / CX100 / CX50 & Cona  / IWS2000; BG4000; Beosystem 1200 + BV1600.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sun, Apr 10 2016 8:17 AM
If the coils are good, it can be rebuilt to any spec.
MJBeo
Netherlands
Posts 270
MJBeo replied on Sun, Apr 10 2016 8:33 AM
Dillen:
Thanks for the quick reply, that is good news! Can this be done by these guys: https://www.schallplattennadeln.de/mmc-repair-english.html. I found them through Beoworld. Or are there others?
PS my apologies Martin for my very slow reaction on the RL tweeter and components for BM5500, I will really get back to you Smile
Dillen
Posts 13,191
Dillen replied on Sun, Apr 10 2016 9:16 AM
Yes, those german guys do a great job.
Peter
Earsdon
Posts 11,991
Peter replied on Sun, Apr 10 2016 6:50 PM
Axel repaired an MMC2 of mine in the same condition. Apart from the cut in the body, you would not have been able to tell it from new.
Peter
ProGram
59269 Beckum, Germany
Posts 383
ProGram replied on Sun, Apr 10 2016 7:03 PM
Axel is no longer repairing B&O pickups, He gave the business to the guy that helped him all the years:
F.J. Schulte
Schnadweg 28
33142 Büren
Telefon: +49(0) 29 51 / 60 25 08 4
www.tonabnehmerservice.de
www.tonabnehmerservice.com
www.retippingservice.de
info@tonabnehmerservice.de
Axel has a lot to do with other brands. I'm waiting nearly 6 months now for a thorens moving-coil now
Chris
AudioOrigin
Posts 53
Yes as long as the coils are ok it can be refurbished, also there are plenty of spare end parts in stock so that can be replaced at the same time, current average turnaround 2 weeks
http://www.audio-origin.co.uk/retipping-stylus.html
Alistair
AriPaija
Posts 1
AriPaija replied on Thu, Dec 20 2018 7:55 AM
"cut to the body". I have an MMC4000 with open circuit on one channel an planning to open it but how; is the only way to cut the body with Dremel and clue it back together? Is the cut made in top and bottom, would make more sense than on sides? Any experince, success or fails, contribute. Ari
Dillen
Posts 13,191
Dillen replied on Thu, Dec 20 2018 9:34 AM
The cut is merely a few milimeters to the bottom side near the tip.
It's made to gain access to the cantilevers rubber suspension inside the front portion of the cartridge.
The whole cartridge is not opened.  This is quite difficult - not impossible but difficult - and repairs to broken coils is often impossible.
Page 1 of 1 (9 items) | RSS
