hello,i just bought a beocom 6000/beotalk/beoline bundle and i need some help in order to pair all power supplies (the problem is their voltage)Here is a complete list of all the items 4 handsets4 pyramid bases, all with status leds (no power information on the labels)1 beotalk 1100 (no power information on the labels)1 beoline isdn (label says dc 7.5 v )6 power supplies: -4 look exactly the same (label says: ontop model a30750g class 2 output 7,5v 0,5A) -2 look exactly the same (label says: ontop model a30930g class 2 output 9v 0,3A)I thought the four 7.5V power supplies were for the pyramid but, according to the labels, one of them is for the beoline !I would like to know if there are compatibility issues between germany (where i bought from) and italy.
The menu structures is slightly different from another beocom 6000 i already have (some kind of "total cost" voice is present, and there isn't the "language" options); is it due to an old firmware ? would the update give important improvements?
And, as three handsets need battery replacement, i wonder if you have some advice about where to buy new ones (and which models), because as far i can remember at the official dealer it cost me about 30 euros!Thank you all for helpingfrancesco
