Beosystem 1 Beomedia1
jdonkor
Posts 7
jdonkor Posted: Mon, Jul 23 2012 9:27 PM
Hi, I have a Beosystem 1 with Beovision 4-50 connected with a Beomedia 1. The connection is a VGA cable connected to the Beomedia 1 and pc on the beovision 4-50. I also have audio from the beomedia 1 to V.Aux on the beosystem 1. I also have a masterlink cable connected to the beomedia 1 and beosystem 1. I want to use the ir on the beosystem 1 to control my beomedia 1, please if you have an advice let me know.
 -Thanks
Francois (Frank)
Montreal
Posts 4
Silver Member
Hello, happy new year.
I want to do the same thing as you. Did you find a way to do it? I also have a probleme. I am trying to connect the S-Video cable to the Beosystem1 and not connection the PC connection to the TV, I can see the image only in black and white. I am trying to find out if it is normal or I have a problem with my TV or my Beosystem 1. Can you hel me ?  Thank you
expoman
Posts 182
Silver Member
expoman replied on Wed, Jan 9 2013 5:26 AM
You need to connect a mini jack stereo cable from the Beosystem 1 V Aux control output jack to the input on the Beomedia marked IR next to the Masterlink plug.  You then set the external source of V Aux to Beomedia in the external sources menu of the Beosystem 1 for it to operate from the B&O remote thru the Beosystem 1.  If Beomedia is not a source choice you may need to have the software updated in your Beosystem 1.
expoman
Posts 182
Silver Member
expoman replied on Wed, Jan 9 2013 5:28 AM
The output of the Beomedia is only black and white on n. music and n.radio.  check photos or web to see if you have color.
Francois (Frank)
Montreal
Posts 4
Silver Member
Thank you for you answer.
I have a separate IR for the Beomedia1.  I use the Service mode to go on the Web and it is still black and white. When I connect the SVideo or RCA video output from the Beomedia to and other TV I have, I can see the color. So I don't know why I can not see the color on the B&O TV with the Beosystem1?
Francois
Page 1 of 1 (5 items) | RSS
