Hello,
I disconnected when installing / deinstalling the different components of the motherboard, the red and the black wire which goes to the internal aluminium box FM tuner.
Can anyone who has a beomaster 1900 opened , send me a very detailed picture of the aluminium box little FM tuner so i can reconnect the black and the red wire again to the aluminium box at the right places?
Thanks,
Eric
Does this help?
https://beoparts.com/2014/11/30/tuner-fm-frontend-8050070/
yes, perhaps. It is a small image but quite detailed.
Thanks. All works fine now. Also many thanks for the electronic components kit from Martin.
Again the good old sound quality from B&O.
Regards,
I Eric
I don't have any sugest to you, regarding to solve Your problem.
Let me to congratulation you to have a B&O 1900
I have one also! But the volume and soumd controls does't work
I try to find someone here to help me
regards
Rui
Where, Rui ?
