BLGW 1.4.1
This post has 3 Replies | 2 Followers
beoandy
sissi not kangaroo
Posts 329
beoandy Posted: Tue, Jun 21 2016 11:14 PM
Changes in BLGW 1.4.1 since previous BLGW SW version 1.4.0:
Corrections and improvements
  • Improved Khimo configuration syncronization
  • Updated Philips HUE user creation to be compatible with latest Philips HUE API changes. Now username will be automatically generated by the Hue bridge.
  • Improved error handling on IP camera connection, before this, in some circumstances the web panel kept reporting "error" forever.
  • Solved an issue with network Static IP handling, when the BLGW was started without active network connection, it was reverting back to DHCP.
  • Load resources:
    • Corrected handling of duplicated names while importing resources.
    • Changed default name to only use the suggested name without adding area/zone to the name.
  • Bugfix: [HAGW-524] Cannot get cover browsing when selecting BM5 N.MUSIC on BS35 (or A6 or EZ2)
  • Bugfix: HAGW-517 | Custom strings does not work after update from V1.3 to V1.4 (Used on Rako system): When using end of line addresses were not escaped correctly.
  • Bugfix: HAGW-517 | When products go "offline" BLGW removes source information in the interface tab.
BS Ouverture, BS 9000, AV 9000, Avant 32 DVD, BV9, BV6-22, BS 5, BS 4500, BS 7000, BC 9500, Beo6, BL Penta, F1000, BLGW, etc....
DocLeisure
Posts 101
DocLeisure replied on Mon, Jun 27 2016 12:54 PM
Hello,
my BLGW wont update, it only says "Preparing to download the latest Firmware", but nothing happens.
Did anyone Encounter similar Problems or suggestions to solve this issue?
Thanks in advance
Seanie_230
UK
Posts 2,278
I had this problem a while ago.
Set your BLGW to DHCP and try again
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
DocLeisure
Posts 101
thanks for the answer, a "hard reset" did the job ;-)
Best regards
Page 1 of 1 (4 items) | RSS
DigiCert Secured Site Seal
