Hi there,
one of my BV7 40 MK3 seems to be faulty after a thunderstorm (no picture, no backlight). I checked the tests described into the service manual. It seems to be a problem either in the PCB04, 03 or 05.
As there weren´t the correct voltage onto the 04 I assume that changing this board might be most valuable.
Question: I can get a 04-board from MK4 (8004446) - is this compatible to the MK3 one 8003601 ?
THX / Regards
Tom
It is possible and working fine
