Is there a balance setting in the Beomusic or Beosetup app? Balanceis fine with a CD in the 3000 and Beosound 5 sources.
sorry for the three posts
Problem solved. But do not know what the problem was. I reconnected the Essence to the Beosound 5. Both speakers worked, but for the static problem I experience when the Essence is connected to the Beosound 5. I disconnected the 3000 from power while using the 5.
I then reconnected the 3000 to power and reconnected the cables to it and now all works perfectly again. I had previously checked the cable connections and reconnected them with no success. Maybe disconnecting the 3000 from power did something.
Thanks for the suggestions!
Argh, I hate problems like that! Even though I'm happy they went away I always dread them coming back and not knowing the solution.
Jeff
