Beogram 4002 (5513) Speed Too Fast
Kenny
Ohio, USA
Posts 2
Kenny Posted: Mon, Jul 18 2016 5:21 AM
I have a Beogram 4002 (5513) and the speed is too fast. I have to dial it way back on the pitch control to get it to normal speed. I wanted to adjust it so normal speed is normal on the pitch dial but I can't find the speed trimmer pots. The board I am looking had does not seem to have pots in the positions I see speed trimmers in the service manual nor pictures online? did they do something different on the 5513 model? I've got everything working great except that.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Mon, Jul 18 2016 7:18 AM
Welcome to Beoworld !
Beogram 4002 came in a number of different versions.
You need the correct manual for your deck type.
You will most likely find the speed trimmer(s) in need of replacement(s) - plus a few others.
That's very common.
Kenny
Ohio, USA
Posts 2
Kenny replied on Mon, Jul 18 2016 8:12 AM
Somehow, even though I didn't have the right service manual, I figured the one from my model would be hard to find. I found it
I started messing with the 33 pot and then the motor stopped working. which i figure is a sign of a bad pot. I messed with it some more and now no power. I hope it is just the pot, but now I'm aftraid I blew a fuse or worse. It looks like the 45 pot was already replaces with a large square unit. do you know where people are getting these replacement trimmers?
Dillen
Posts 13,191
Dillen replied on Mon, Jul 18 2016 9:09 AM
Any good electronic component supplier will have them.
Page 1 of 1 (4 items) | RSS
