BV 7-40 how to identify which version it is?
JulianJ
Posts 66
JulianJ Posted: Thu, Jul 21 2016 5:57 PM
Dear All,
I have recently inherited a BV 7-40. How can I tell which version it is & more specifically if it has DVD or BluRay?
The lettering in the top right is in white so I understand it is at least a Mk 111.
Thanks in advance for any help!
Kind regards
Julian
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Thu, Jul 21 2016 9:19 PM
Hello Julian,
It all depends on the type number. This will be a four digit number beginning with a 9, which will be in the greenish grey sticker underneath the left hand removable panel as you look at the back of the TV screen.
If you have a UK version and it is indeed a Mk3, the type number will be 9379.
Lee
JulianJ
Posts 66
JulianJ replied on Tue, Aug 2 2016 2:45 PM
Hi Lee,
Thank you for your help, the type number is indeed 9379.
As such I guess the TV is find with a DVD player as opposed to a Blu-Ray?
Kind regards
Julian
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Tue, Aug 2 2016 7:16 PM
This does indeed have a Standard Definition DVD Player installed.  You can have a Blu-Ray module retro-fitted (if you can find one - and there's a small chance I may actually have one somewhere should you want one) but this will need fitting by a B&O engineer as it also involves a software update.
Lee
Page 1 of 1 (4 items) | RSS
