BV10 cable tuning taking ages.
Marcello
Posts 213
Marcello Posted: Sat, Jul 23 2016 9:44 PM
Something strange happened tonight. I turned on our BV10 (DTV) and I was presented with the country selector. After that, I was asked to select which inputs to use for tuning. It became clear that somehow the TV had forgotten the tv channel list.
So I selected Cable only, selected the homing frequency and network ID from my provider (we use DVB-C in CH) and I started the tuning the process.
The TV started populating pretty quickly the channel list. Then it started looking for other frequency. It has been going on like this for 1 hour and a half. Is there a way to store the partial list? If not how long shouls it take?
In the past I remember adding new channels and the TV was a fast process (a few minutes). Should I have the TV checked?
Thanks for any tips.
For what is worth, other settings (sources and connections) look to be ok (before starting the tuning I pressed VMEM and I was taken to my expected source)
Page 1 of 1 (1 items) | RSS
