N Radio is not working
Catrijo
Posts 13
Catrijo Posted: Sun, Jul 24 2016 11:35 AM
Yesterday I configured my Beosound 5 / beomaster 5. I just played a few songs from the internal harddisk and this worked well.
This morning I tried N Radio for the first time, the main reason why I bought this B&O (second hand).
I am very surprised that only 1 of the more than 200 internet radio channels I tried worked.
Please help anecdote with a solution for this or.... is N Radio outsourced by B&O?
Thanks,
Catrijo
Millemissen
Flensborg, Denmark
Posts 14,680
From the User Guide page 22:
'To listen to radio, the music system must be connected to the internet and you must register through the BeoConnect software. Refer to the BeoConnect guide for more information.'
You must register through the BeoConnect software!
Catrijo
Posts 13
Catrijo replied on Sun, Jul 24 2016 12:46 PM
Thanks,
but I got this message by the BeoConnect registration tab:
Welcome to the online registration of your Bang & Olufsen product, which is no longer required.
Also until just now (after a few hours trial): 3 radio channels became alive :)
Millemissen
Flensborg, Denmark
Posts 14,680
Allright - that is new to me.
Maybe it is just a matter of waiiiiiting, then.
Gregg
Colorado USA
Posts 143
Gregg replied on Fri, May 15 2020 2:38 AM
So I have a similar question. I just got a Beosound 5, and it has a lame mix of N-Radio channels. On the other hand, my Avant 55 1st gen I'm able to get all the latest internet radio stations. How does one get the beosound 5 to get the stations on the Avant?
perriama
Posts 30
perriama replied on Fri, May 15 2020 8:50 AM
I have a similar issue. Only I don't have any listing of stations in N.RADIO at all. Tried to register through BeoConnect and got the message regarding registration not being required. Spoke with B&O support, and they provided a NRADIO.reg file to enter into the registery of the playing machine (in my case a BeoMedia1). This didn't work? I have full connection to the internet, so not sure what to do next?
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\Bang & Olufsen\BeoPlayer\N.Radio]
"ViewSelection"=hex:00,01,02,03,04
"BufferTime"=dword:00000005
"ServerURL"="http://nradio.beoplayer.com/nradiodata.asp"
"UserId"="60B1D8994C224AC69B91931AE710521A"
"SoundIcons"=dword:00000001
"EnableDebug"=dword:00000000
marexy
Posts 710
marexy replied on Fri, May 15 2020 1:22 PM
Try factory reset... do the last SW update....then just heve the BS5 ON over the night or 24 hours.
N Radio stations should be all there after some time.
Pat
Posts 152
Pat replied on Fri, May 15 2020 3:37 PM
You have to clear databases in the service menu, common issue
Page 1 of 1 (8 items) | RSS
