Hi Lee,
referring to the manual, the idle current has to be around 50 mA, which corresponds to 18 mV (0,018V) over the low-ohm-resistors (TP200 to TP201). So 0.07mV is fairly low. To measure the volts is much more convenient, but when you read the amperes in series, it's more accurate, At the speaker output itself - the speaker switch has to be on, but no speaker connected- , the voltage should be zero. This is the position, where plus and minus supply voltage meet through the transistors and emitter resistors to cancel each other out. So this section is "business as usual"
Chris
now I know what you are talking about, never knew this site. And yes, he doesn't say, where he measures it. And that he connects so many speakers to it... i have no words.
Lee:Hi Chris, Yes I would've thought that 0.07mV would be so low as to cause crossover distortion.
this can be heard at lower volume, but it's not harmful.
ProGram: Lee:Hi Chris, Yes I would've thought that 0.07mV would be so low as to cause crossover distortion. this can be heard at lower volume, but it's not harmful. Chris
Sorry Chris, but that's rubbish.Most people won't notice crossover distortion at LOW volumes but I can assure you that it can easily be heard at higher volumes.And I can also assure you, that's it's definitely harmful! Not to the amplifier (though it could theoretically run a bit warmer) but to the tweeters in your speakers, due to the largecontent of 2nd, 3rd etc. harmonics (which typically are too high for us humans to hear but at a considerable level and it all getsfiltered to the tweeters).
Adjust according to the manual and you'll be fine.I see no reason at all to set the idle current any different.
Dillen: Sorry Chris, but that's rubbish. Most people won't notice crossover distortion at LOW volumes but I can assure you that it can easily be heard at higher volumes.And I can also assure you, that's it's definitely harmful! Not to the amplifier (though it could theoretically run a bit warmer) but to the tweeters Martin
Martin,
It's the amp, I was talking about. But I thought, the distortion is more at low volume, sorry for that. It is really long time ago since I heard such fault.
Dillen: Adjust according to the manual and you'll be fine.I see no reason at all to set the idle current any different.
Agree.
Each transistor has its "working space". Setting it up below or to high will affect this.
Setting it up with a low idlecurrent, the interaction between the positive and negative transistors will be affected and result as crossover distortion.
Setting it up to high will result in distortion at higher levels as the signals clipps against the powersupply. With damaged transistors or drivers as result.
The mentioned site sounds interesting for the novice, but accually referres to adjusting the idle-current and offset-voltage. But with wrong values.
Adjusting the offset to 0 mV (plus or minus 5 mV) is needed as it is a DC coupled design. It lacks an output capacitor (not needed and less distortion)
