Hi..
I am in the process of buying a set of mk3 beolab pentas. They are in very bad shape,but amplifiers should work,and that is what I need :)
I have asked the seller if they power up, and he responds that when he plug them in, both led turn green a second, and then red. He does not own a beomaster to test with.
Is that led behaviour normal without any master attached?
It is quite a drive, and I will take a BM4500 along to test with, but if someone tells me that the led behaviour is wrong, then I might think twice :)
/weebyx
