Hi
My BV6-26 defaults to format 1 and use it only with an Apple TV for video through a converter - so I have to manually select Format 3 everytime I use it - does anyone know what the geometry settings should be for Format 3 - I can then change Format 1 (which is the only settings I can see) to Format 3 and nbot have to change the format setting manually? - at least that's the theory!
I guess the BV 6 is set default to Format 1. I don't know if you can change the default settings.
However it should automatically find the right format every time you turn it on. My BV 6 is connected to a WD TV live box with a HDMI to DVI cable. It Works fine. Which input socket do you use on your BV 6 ?
You write, that you can only see Format 1 and 3. You know that you can switch between formats with the keys 1,2 or 3 on the remote? And in Format 1 you can use « or » to adjust picture. In Format 1 and 2 you can use 🔺 or 🔻 to move the picture up/down.
