CD, turntable and active speakers?
TBOR
Posts 2
TBOR Posted: Sat, Aug 27 2016 11:17 AM
Sorry for being confused by mixed information from various sources... but I simply want to use the combination of CD-player, turntable and (possibly) active speakers, all from B&O.
Is this possible with Beocenter 8000/9000?
Or do active speakers go better with eg. Beocenter 2300 (where I have to connect the turntable through AUX)?
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
You can't use active speakers with BC8000/9000 as there is no powerlink output.
BC2300 would work fine but your turntable will need built in RIAA pre amp or a stand alone.
Regards Graham
TBOR
Posts 2
TBOR replied on Sat, Aug 27 2016 11:43 AM
Thank you. I guess a Beocenter 9500 would do the trick.
Page 1 of 1 (3 items) | RSS
