Beolab 4500 - connect to Linn preamp
swedane
Posts 1
swedane Posted: Sat, Aug 27 2016 5:12 PM
I would like to connect my Beolab 4500 wall speakers to my Linn AV 5103 preamp.
As I understand it the best (only) way to do this is to use the line in on the Beolab 4500.
I tried to connect a standard 3,5 mm plug, but it does not fit (can't push it in).
Is the line in connection to be used with a special plug or should a standard 3,5 mm fit?
Thanks for any advice in this matter
Page 1 of 1 (1 items) | RSS
