Hi
I have a pair of Beocom 2 phones however on one of them the display keeps fading. If I power off the phone and switch it back on its OK for a while - I didn't think it was the battery as doesn't the display normally tell you if the battery is low but also the display is faded when on its base charging. Has anyone had this problem?
I have exactly the same problem which coincidently started on September 5th
can only think to change the battery but like you, i am not convinced that's the solution
