Cant get my S8 hub to work with the tv remote
Fredrik858
Posts 5
Fredrik858 Posted: Sat, Sep 10 2016 2:09 PM
Hello,
I have a problem with my S8
I have connected it the right way and it works but i cant use my philips controller to regulate the volume.
I have tryed the connection instruction to make the hub recognize the controller but without success.
(will not turn green)
I use optical for the tv
i have an Philips 55PUS7181 TV
tuttivini
Posts 186
tuttivini replied on Sun, Sep 11 2016 4:09 PM
I think this is because your Philips remote uses RF signals instead of IR signals.
I also have a Philips tv (55pfl7008) and this remote uses RF. Very handy because you don't have to aim te remote, but unusable if you want to use it with a B&O S8 hub I guess....
Fredrik858
Posts 5
ok,
thank you :)
Fredrik858
Posts 5
ok,
thank you :)
Page 1 of 1 (4 items) | RSS
