I just aquired a BV7-40 mrk 1 and would like to use the YPbPr input.
EDIT EDIT EDIT
Found a solution ... Will try such a device:
http://www.ebay.com/itm/HDMI-to-RGB-Component-YPbPr-Video-R-L-Audio-Adapter-Converter-HD-TV-OE-EU-Plug-/252416443666?hash=item3ac5314512:g:Z5MAAOSwMNxXVnSn
Kind regards
Ravsted
Hope it works, I use the following and plug into a SCART adapter plug which lets my Apple TV v4 go into a BV4-42
http://www.jaycar.co.nz/hdmi-to-av-composite-converter/p/AC1720
