Beocord 4500 C-tape stuck!
This post has 1 Reply | 0 Followers
mariaklem
Posts 1
mariaklem Posted: Wed, Sep 21 2016 2:22 PM
C-tape is stuck
How can I remove a stuck cassette tape manually? The casette started playing, then stopped, and is now stuck with the player parts in the casette. It wont play or forward/backward, but lights and power are on. The lid will open.
Total system composes of three parts: Beocord 4500, Beomaster 4500 and Beogram CD 4500. Old goodie.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Wed, Sep 21 2016 3:15 PM
Rotate the flywheels by hand (without power to the deck).
The right flywheel goes counter-clockwise as seen from above.
The left one clockwise.
After a few revolutions, the tapeheads will disengage.
Then replace the belts. They are slipping and causing the problem.
Page 1 of 1 (2 items) | RSS
