Yet another Beolink 7000 problem...
This post has 0 Replies | 0 Followers
TheTinman
Posts 30
TheTinman Posted: Thu, Sep 29 2016 7:57 PM
I have recently acquired a reasonably clean Beolink 7000 remote.  I have done the capacitor change without any issues.  Since I can do microsoldering, this was pretty simple for me to do.  The main and backup battery are both good.  The remote works flawlessly in the charger.
But when I take it off charge, the remote will go to sleep as it should and then in a few seconds start to blink frantically.
When I tap it, the remote then wakes up and works normally.  It continues to do so as long as I use it.  Once it goes back to sleep, the rapid flashing starts again.  I can put it on the charger and it works fine.
It does not SEEM the battery is bad, as it tests just over 6.4 volts, it is a nicad pack, replaced 2 years ago.
According to the forum posts, the LED display should flash if the battery gets low, but it does not.  I have not tried to purposely run it down, as I'd have to keep constantly using it to keep it from going into the flashing routine which includes the LCD backlight.
I am confused... IS it the battery, or is something else wrong?  This is my ffirst Beolink 7000 and while searching the forum, I have not found a solid answer to this.
Thanks.
Page 1 of 1 (1 items) | RSS
