I have had my B&O Beomaster 2400, Beograd RX, Redlines for about a year now. Love them, but about 3 months ago things started messing up with my 2400. I fire it all up and get about one side of an LP and it switches to FM2. I will go over and switch it back. About 5 minutes later it switches back to FM2, it just keeps doing that more and more, until I give up and turn it off. I have no idea what to do. I have seen some topics on this, but it doesn't seem to be quite the same issue. It was fine, nothing changed, then it started out of the blue.
Any ideas?
Welcome to Beoworld !
All very common after 40 years.Capacitors, rectifier, even bad or wrong front panel lamps can cause this.Capacitor- and lamp kits etc. are available.
Having same issue. Where would you start? I am a complete neophyte! Thanks!
