I have a Beocenter 7000 of which has been damaged in house move. I think yellow wire has become detached from connector as LED lights up like Christmas tree. Can anyone advise where yellow wire and brown and white should be connected to LED board.. Control button retainer has also broken but sure I can fix with sticky pads... Shame I loved this centre!!!😢
How on earth can a house move result in leads becoming detached from a connector inside the Beocenter?A photo could help us help you.
See image below.. brown white was connected to right pin I think but yellow was detached when I opened up...
Image address:
http://archivedforum2.beoworld.org/members/MYbeo7000/files/Yellow/IMG_5F00_0796.JPG.aspx
Cant seem to attach image?
I connected yellow lead to shiny pin on left and brown white to right pin. Now getting P on display no response on control panel.. Think it's all over! Gutted.. Should have taken more care when in transit....
image url below
Any advice would be appreciated
Regards
Matt
Sorry but trying to re address problem. Maybe I should re post?
please see link below my journey was a house move and looks like I must of have something heavy on control board buttons as retaining clips have broken so am looking for a way of retain the board.. maybe drill holes in facia then screw to retain. Don't really won't too but seems only option? On opening connection to LED board must of slipped off as have round spade clips of which must of been loose. Need to re connect but not sure which pins to connect. Wires are yellow stripped white and brown white stripped. Please see link below for image hopefully will open if not I can send image to your email. Again sorry to ask again but really won't my Beocenter to work again.
IMG_0795.JPG.aspx
regards
matt
