Hi again, strange question, or not... BV7-32-MK1 with a set of bl8000s and NO centre speaker should function quite healthily, right?
symptoms: hear the music on a DVD/ SKY but any voices/narration sounds fluttering and very weak and at volume 51 it should be like im being shouted at. have i got the set up wrong in the speaker/sound menus or is it just a case of i haven't commanded the beo4 to SPEAKER-2?
im not at home now to try again. any advice would help, thank you.
hope this makes sense.
jason
sorted. speaker-2
